Help with oxygen sensor?
HillACCORD
i dont know why my last thread was"moved and closed" but I DID SEARCH
and couldnt find the information that i needed, so im asking
1. are the 2 oxygen sensors the same?
2. which brand is the best
3. where can i order it from
02 CG5 SE
florida
ill try to help you before this gets closed
primary
secondary
as you can see, they have 2 different parts numbers
iono where a good place to buy them but i assume your local auto parts store may have some if not universal ones that need rewiring
02 CG5 SE
florida
the universal ones that you posted need to have the old plug cut off and rewired onto the new one. the other ones, oe spec, are direct replacement
denso is a reputable brand but i never used their o2 sensors
AFAccord
Spangdahlem, Germany
1. On F23A1, both actually sensors are the same, but the connectors are different, which is why the direct fit model numbers are different, but the universal model numbers are the same. On the F23A4, the actual sensors are different.
2. OEM (aka Denso)
3. You posted the location above. :)
i found this...which was recomended...but i dont know which ones to buy
http://www.densoproducts.com/resultsApp.asp?AAIA=1362989&productCategoryID=2
If you feel comfortable splicing four wires, save yourself the cash and buy the universal model.
Your car probably came from the factory with Denso sensors. :thumbsup:
HillACCORD
thanks AFaccord, that is exactly what i needed to know
