redEYEjedi
Finally got my new wheels in, but now they are rubbing. Wheel size is 17x8 with 35 offset I believe.. it wasn't indicated on the back of the wheel.. but the lip is about 2" give or take. Currently running 225/45/17 tires and dropped on Pro-kits.
I seem to rub more often in the front than the rear, though Pro-kits tend to have a "boat like" look with the front slightly higher than the rear.
What are my options?? Plus my rear is almost flush but the front stick out... sigh... Thanks in advance.
Addition:
Usual responses would probably be roll fenders or change tire size.
How is the process of "fender rolling" done?
What is a suggested tire size for my situation? Do I run some negative camber to fix the situation as well? If so.. how much?
Thanks.
Addition:
Thanks.
