how low to go with 19's on
accordman1
Albany ny
I was wondering if I have 19 inch Axis Crux wheels with 225/35/19 inch tires. How low would you go with k sport coil overs. I want to be low and fill the wheel gaps so it looks even. I just do not want to be too low that I can't make it anywhere since the car is going to be a daily driver. I was thinking 2.75 front and 2.50 rear since my rear has a custom trunk and all that weight makes it sit a lot lower in the back. Let me know opinions on what I should do. Thanks
CHID0
Boston
I have a similar setup but with Omni's and i can pretty much go as low as i want but I have a coupe and i think sedans are more restrictive as far as fender clearance.
nyknick1015
NYC
get ready for your rear to scrape your tires when u have ppl in the car its annoying as hell
well that is more or less offset... u can go as low as u want... 2.75 on 19's u mite have to take out some wheel well stuff but u should be able to go that low...
DarkSideAccord
nadeshiko fobz ftw..
depends on wheel offset... :coffee:
u could always roll ur fenders to make it fit better :coffee:
Tx_Accord98
the axis crux should be a 45 offset if they are 4lug. I got 19" Axis Se7en wheels and that is what they are. 225/35's don't rub with that combo on my ride. My rears are not rolled, but i don't have a fender liner in the front wheel wells.
i might have a 1 finger gap in front, and i can't put a finger in the back. my teins won't let me go lower, so i'm stuck with that.
hendizzlez
Westminster, CA
i recommend rolling ur fenders so you can tuck tires :thumbsup: lol i rubbed with 18's, with only me in the car + going over a dip..
accordman1
Albany ny
The offset is 45. So I might have to take out the plastic fender things in the fronts. I was planning to not go as low in the back. Just want the front like 2.75 just to look all even and not a gap. I do not know what rolling the fenders are I have never done it or seen it done.
Tx_Accord98
you shouldn't need to roll your fenders with that setup. it is the same as mine and i have NEVER rubbed in the back. i only rubbed when i had 235's on.
