Hey folks!
Just finished putting back my h23 in the accord, was going to calibrate TPS but noticed it had no voltage at all.. Checked other sensors, like MAP, no voltage..But battery voltage is good, car will crank no problem (didnt try to start it; cranked with fuel pump/IGN fuse out, to prime the engine)
Now, more details;
Originally was a f23a1, made little tweaks in wiring to run h23 obd2 ecu, everything ran fine. This season i had to modify the IAC to make it a 2 pin for obd1 conversion, and my intake manifold doesnt have an EGR valve so the connector is left unplugged. Other thank that, i did not change anything. I tried 3 ECU's, all with the same results, no power to sensors.
I'm doing some research on forums, my factory manual, trying to troubleshoot when i can find time, but if anybody would have a clue that would make my life easier, ler me know!!
Now, more details;
