So I drove about a half hour to meet up with my friend tonight after work. I was in 5th gear for about 15 mins, everything normal, then all of the sudden it pops out and goes to neutral. I put it back into 5th gear, and as soon as I let off the clutch and give it some gas it would pop back out of gear.
When I got to a stop, my transmission was making a grinding noise in neutral with the clutch engaged. When I would disengage (press) the clutch, the noise would go away. It also makes this grinding noise once rolling throughout the gears.
Through a little research I did it sounds to be a bearing making the noise right? But what is making 5th gear pop out?
Please help.
Please help.
