nitrous control on an AT
accordpower99
pcola, FL
yah but their is an over drive at least on the 96-97 4cyl auto, keep your car in D4 and drive it up to 60, listen and feel how many times it shifts, i didnt know it until the honda tech told me.
blacknight
Superman, uh mod
Bergen County, NJ
allicedout said:
I hear its safer to run nitrous on Auto's then manuals.
Actually, I think it 's safer for manuals.
With a manual you can use a WOT switch.
In between shifting gears, you're off the gas and the spray is not engaged.
But begin spraying in 2nd. If you start in 1st you'll get wheel spin
Here4U2nv151
Tacoma, WA
HandoEX said:
I disagree. The safest way to add power to an auto is to use nitrous with a window switch because with this sort of set up you can add power to the car without adding it during shifts. If the power is only there when the car is not shifting gears, there is much less strain put on the transmission.
+1 point for you.
