Not worth the aggro
Hobbit
UK
Well the trans fluid needed to be changed and after watch vid after vid and reading thread after thread I decided it ain't worth the aggro of clambering under the car and getting dirty followed by struggling to fill the trans. So off to nearest Honda it went
Cost - £75 inc parts , labour and VAT at 20%
Oil was £12 a litre so as I said not worth the aggro, I now have a much nicer car to drive with according to Honda health check nothing wrong with the car :)
And for everyone saying fill thru dipstick well that's not how Honda do it, they undo the 17mm bolt on top of the trans marked ATF :)
Varnell
Charlotte, NC
As long as the maintenance gets done, diy or at a dealership. Once you've identified the bolts and scrounge up your tools the job isn't any more difficult than changing your passenger side wheel.
Some DIYs just aren't worth the aggro (British expression?). Window Tint, for example, just isn't for me.
Pretty simple actually, but it's all about priorities. Really the same as changing the engine oil, actually easier since there's no filter to deal with. Jack up the car, remove drain bolt and drain fluid, replace drain bolt with new crush washer, remove fill bolt on top of trans (need one long socket extension of connect a few together), then with a long funnel fill w/the appropriate amount. Replace fill bolt. Definitely do not fill through the dipstick, who said that lol.
Like your sig btw, so true.
honda does :lawl:
you put the 3.5 quarts in through the fill plug, then add in through the dipstick hole to the proper level.
source: looking at the 8th gen service manual right now :lawl:
Varnell
Charlotte, NC
You may excuse Chris. I don't think he has used a tranny dipstick hole in a few years.
Edit: That sounds way worse than I intended. :Whoa:
Hobbit
UK
To funny , but yeah Honda suggest thru the dipstick hole to the point I've made a filler with a funnel and fish tank hose in prep for the change then decided sod it lol
honda does :lawl:
Never did this when I was auto and that slushbox was solid. :lawl:
Yeah let's go with that. :lawl:
just did mine for about $50 in fluid, $3 for a long ass funnel, and around 15 minutes of my time. thats what...30 or 35 in the queens currency?
weird, I use the dipstick tube to fill, always did when I was a Honda tech to, so did the other guys.
Just gotta make sure you use real Honda fluid, ours is -WAY- different than others, they're just red too. Our auto is closer to a manual, btw. This aftermarket stuff that does Dex/Mobar/etc -AND- Honda is junk.
was that on cars like civics where the fill plug is right above the drain plug? fill it up till it spills :lawl:
doing it myself means i have control over what fluids go in and the dealer won't be able to charge me $80 :lawl:
