kn106518
ok So after 3 weeks of waiting my freaking skunk2 coilover sleeve finally came today.
But with a ****ing problem. on outside the box that i got it say the PART # is 517-05-0700 Honda Prelude 92-01.
and the print # on the FRONT spring is 0700.250.10s. i think it mean 7in height and 10kg/mm spring rate. (however, i check the skunk2 website, the accord 98-02 4cyl has the same 0700.250.10s. NOW THE **** UP IS THE rear spring.
The Rear Spring is 800.250.8s. 8in height and 8kg/mm spring rate. But the accord 98-02 4cyl is 700.250.6. THE PRELUDE SPRING THAT I GOT is 1in Higher but at least the good thing is i get 2kg/mm stronger.
Now my question is this. CAN I USE THE SPRINGS FOR MY Accord 99 4cyl sedan or not?
PLZ IF someone can help me that would be great. plz i'm in desperate time here. I don't want to install it on my car, and i can't return it. if someone can give me just a reasonable answer. THANK YOU THANK YOU
