Ok, started my led project, here are some pics
Discussion in 'Detailing, Paint, Interior, Show mods' started by talontsiawd, Sep 10, 2006.
  1. Mar4elo
    Mar4elo Member
    11
    Sep 8, 2012
    canada
    ok. great. Thanks for help.
    Another question i wanted to ask.
    what kind of bulbs i must order to change my door bulb, trunk bulbs and bulbs in a Auto Gear Shifter?
    can somebody help with types of bulbs and how many i of each i need?
    P.S. Just want to make a list and than order everything in one time.
    Thank you.
  2. Jephu
    Jephu 6GA Supporting Member
    1,211
    24
    Mar 26, 2009
    San Diego
    Buy SMD 5050 Led.
    door (4), map(2), license plate (1), parking lights (2) and trunk (1) are all t10 bulbs (194/168)
    gear shifter (1) is t5 (#74)
    Dome: 36MM
    Glove Box: 31MM
    Cluster: T10 194 and T5 74
    Reverse: T20 7440
    Brake: T20 7443
    Third Brake lights: T20 7440
    Front turn Signal: 1157
    LED Flasher Unit: EP34 <--- you need this to fix hyper blinking. You can also wire 8 ohm 50 watt resistor for each turn signal.
    Install CCFL instead of led for optimal trunk light.
    http://www.6thgenaccord.com/forums/showthread.php?t=20641&highlight=ccfl+trunk
    DIY LED Interior Installation Guide Videos on my FS post:
    http://www.6thgenaccord.com/forums/showthread.php?t=33085
    RedRyder likes this.
  3. Mar4elo
    Mar4elo Member
    11
    Sep 8, 2012
    canada
    Guys so....
    I've really hard time with choosing the correct bulbs. Can somebody say if i'm going right way.
    So for 194 bulbs i'll order http://www.superbrightleds.com/more...led-bulb-5-led-wide-angle-wedge-base/199/873/
    But what should i order for 74???
    Does this kind of bulbs must have twist lock instrument like this http://www.superbrightleds.com/more...gauge/pc74-led-bulb-instrument-panel-led/219/
    Or can i order this one http://www.superbrightleds.com/more...bs/74-led-bulb-1-smd-led-wedge-base/227/1062/
    What wide they must be? 3mm 4mm or 5mm.
    Really confused. :(
  4. Dimsumbunz
    Dimsumbunz Member
    11
    Feb 18, 2013
    Poway
    Some one should update the bulb with links t-tffssss
  5. tmanikaran17
    tmanikaran17 New Member
    Apr 2, 2013
    Minnesota
    does anyone know how to change the bulbs in the visor to led?
  6. dbang
    dbang Well-Known Member
    116
    Mar 7, 2013
    toronto
    take a flat head pop out the cover, pop out the bulb, replace bulb with 31mm leds
    also to add which i took forever finding out... the damn clock bulb is a T3 bulb and unit is 8mm diameter base not too sure about height but i think 10mm will work
  7. MrBuTcHeR
    MrBuTcHeR Active Member
    28
    May 14, 2013
    Barboursville, WV
    Anyone have suggestions to fix my needles reading everything wrong?
  8. talontsiawd
    talontsiawd Well-Known Member
    40
    4,380
    23
    Sep 1, 2006
    East Bay, CA
  9. MrBuTcHeR
    28
    May 14, 2013
    Barboursville, WV
    Very Nice, Thank You SIR! I realized it was wrong on my way to work and was thinking I had a mess on my hands. After reading your thread I can easily do it! You are the man!:thumbsup:
  10. talontsiawd
    40
    4,380
    23
    Sep 1, 2006
    East Bay, CA
    As I said in my thread, using a datalogger is a much better way but I got my gauges back perfectly that way. I kept a fork in my car for like 2 months to easily take the needles off with the clear plastic off to get my gas gauge right, lol, the only one that can be problematic as you if you don't get it right, you don't really know until you are on empty and refill.
Share This Page
