p1381 need help
sway
corona/fontana
I had. A check. Engin . Ligjt that kept blinking the checked out the codes it came out to be cylinder position sensor i changed out the distributor and cap car still runs like crap can anyone. Help
Troubleshooting a DTC P1381 (CYP sensor
intermittent interruption) in a ’98–02 Accord L4 or
’96–00 Civic? If you can’t find anything wrong
after following the procedure in the appropriate
S/M, then remove the distributor cap, and make
sure the coil shield is in place and it’s correctly
installed as shown. If the coil shield installation
looks OK, then the ignition coil is the probably
faulty and should be replaced.
Working at a dealer has its benefits
sway
corona/fontana
Thank you very much for trying me out but I don't think that is the problem i just replaced my ignition coil when replacing my distributor
Time for a new dizzy then or double check your install.
CYP sensor is part of the distributor
sway
corona/fontana
Yeah i want you guys for helping. Me out i was able. To fix the problem and for any one with. The same problem. It can be cause by these things
Bad alternator
Spark plugs
Wire set
Cylinder position sensor witch means new distributor
Ignition coil
Bad battery
