There is a path on the passenger side. If your amps are on the driver side of the car then running it across the engine bay then into the cabin is ok, but I still see no reason to run it that way. My car is being borrowed so I will have to go take pics of it, but as I said it should be simple to run on passenger side with a little looking around. Take off the bottom of the dash under the glovebox, the kick plate, and pull the carpet away from the footwell. Should be able to find it.
