Ppr753's Wisconsin 6thGen
ppr753
Oshkosh
This is my 2000 Honda Accord Coupe v6
Black, 134k Miles. Purchased April 2012 in Fond Du Lac, Wisconsin.
Current Location: Oshkosh, Wisconsin.
External:
Blackhoused Headlights
H.I.D. Blubs
Black Eyelid
Internal:
S.R.Intake
OBX Throttle Body Spacer
OBX SS Headers
Custom Headerback Exhaust with N1 style muffler
03 Acura CL-s 6 MT swap (Fall '12)
Suspension:
Lowered on Tien lowering springs (1.75in, 2in)
20mm Acura Sway Bar (Coming Soon Summer '12)
Tie Bar (Coming Soon Summer '12)
Wheels:
Black Painted Stock Rims
In need of new tires (Summer '12)
Plans for the future:
j32a3 swap (hopefully a full CL-s dropout)
New rims and tires
20mm TL Sway bar
fix backing to driver's side seat
replace bulb in clock
25th Anniversary Town of Omro Car Show
Slinger Wisconsin Auto Swap/Meet
ppr753
Oshkosh
SykVSyx,
Your SIG says you plan to 6 Speed and M90, how are you going to install an M90 on a J engine? If you're going to do custom work someday, count me in. An M90 on a J Engine would sound sick.
As for now... Working on finding a shop in town to do work on a 6MT swap. One shop I visited, quoted around $2500-4500 for a CL-s swap. But I am also considering the 04 TL trans.
Mikey
Middle America
Good luck finding a shop who will/can do the 6spd swap. I'd plan on it taking 2-3 times longer and probably twice what they quote you.
SykVSyx
Tee Dot Ohh
SykVSyx,
There is someone in VA that uses the M90 S/C housing and makes a custom arm for it. I can tell you that if you find the M90 charger, it will be $2250 for the rest of the parts that you would need to make it work. That doesn't include the smaller battery, that is strictly the S/C parts.
That price is about right for the swap, although you may want to consider swapping the engine as well if you can find the complete setup from a CL-S.
Welcome to the site, car is a good start. But did you drill holes in the bumper cover for the front plate?
I will have a 20mm TL rear sway bar up for sale this summer.
ppr753
Oshkosh
I actually own the 20mm bar itself. I just can't seem to find 20mm bushings for it.
As far as the license plate, there were two holes with the original plate on it. I Didn't drill any holes.
