Hi everyone. I am having a little issue with the alignment of the rear balance shaft after doing the timing belt replacement. I replaced the timing belt this weekend and the cam/crankshaft belt is correct. But when I went to install the balancer belt, I couldn't remember where the rear balancer gear was supposed to align to. I read the On Demand instructions and it said that there's a service hole in the rear of the block, so I inserted a long 6mm allen wrench into it and turned the gear until it was locked into place, and wouldn't turn in either direction. But the mark on the gear was facing up (contrary to all the pictures I've seen where its facing 5 o'clock) I left it in the 11 o'clock position and everything seemed to run fine. But I took it apart again questioning whether I had done it right. I aligned it to 5 o'clock and now it seems to run pretty rough. The tensioner pullies are set correctly. And the main timing belt is correct. So I suspect the rear balance shaft I out of sync. My question is, the hole that is in the rear shaft, does it go through all the way? Or will it only lock in one position? Because I thought maybe I was 180 degrees off the first time, but it ran fine, but its facing in the opposite direction of all the pictures I've seen online. Sorry for the long post, but I wanted to be as detailed as possible. Any help, especially from anyone who has done their timing belt, would greatly be appreciated! BTW - its a F23
