Rear brakes squeal.
StrongHandOnly
Pennsylvania
I changed the rear brakes and rotors. Driver side rear outer brake pad was at <1. All the other pads on both sides were at 5. No issues with the job. But now something squeals only when I take a right hand turn. Anyone have any ideas on what could be the cause?
The pivot pins were pretty dry. I lubed them appropriately.
Maybe the dimple on the inner brake pad isn't sitting in the right spot on the caliper piston? Just doesn't make sense to me that I hear a squeal only when I steer to the right!
Eclipse99fwb
Navarre Fl
Check that pads are sitting correctly and not loose. Also the heat shield isnt making contact, unlikely but check. Try regreasing the caliper pins again. Keep a eye on your driver side caliper wear though, caliper may be sticking with uneven wear like you had.
