Rear caliper rebuild kit
kamozee
Toronto
Going to get my rear calipers powdercaoted so I need to buy a rebuild kit. Do I only need to buy what is pictured as #1 in the diagram for both sides or anything else?
Thanks!
SykVSyx
Tee Dot Ohh
Maybe it's just me, but the pic doesn't work.
Was it something from rockauto? That's where you should look into to get the parts you will need.
I think your work computer must block a lot of pics, Derek. I see a lot of posts from you saying you aren't seeing people's pictures. My work filters pictures too, but I see this one.
kamozee
Toronto
It's from Majestic Honda. I looked at Rock Auto and I think part 0717757 is the same thing? I'm not entirely sure. It's cheaper on Rock but it's not OEM
SykVSyx
Tee Dot Ohh
You're probably right, so I will have to check on my phone. :eusa_doh:
I can't even get on Majestic's website at work....FAIL.
98ExAccordwv
I'm Old
WV
Item 1 in the image above is what you'll need. You can also go with the item on rock auto, from the picture on rock it looks like its for both rear calipers...but for that price I'd say its just one.
kamozee
Toronto
Should I get the parts from Rock or is it worth the extra coin to get it from Majestic?
SykVSyx
Tee Dot Ohh
I looked at #19261099 on Rock Auto, which I believe is one of the complete kits you can get for both sides.
kamozee
Toronto
Derek, I took a look at the picture of this and it looks like just a set of springs and no rubber seals...
getimage.php
Volo
Vancouver, BC
I have a problem with the brake leak on the rear caliper at the E-BRAKE and lever area. I did change all the seals inside the caliper last summer (bought CENTRIC 14340015 caliper repair kit). And now - less than in a year since - have the same leakage from the same spot.. Any ideas what the actual problem could be?
