gt58
I have figured out the biggest possible box design if you plan on building your box outside the car and dropping it in. building a box inside the trunk is a whole different story but i wont go into that. the sedan is obviously a little bigger and can take a bigger box because of the wider trunk. the coupes tail lights swoop in and take off an extra 3 inches of width.
the two sizes:
sedan max external dimensions:
35 wide, 17.5 deep, 18 tall
-the box will not clear the 6x9's or black box
-coupe box (32x17x17) will clear 6x9's and black box, but if no spare tire is in there will fall thru the floor if it slides back. i recommend brackets to hold it in place if going with the smaller box.
the trunk has more room than the picture shows
coupe max dimensions:
32 wide, 17 deep, 17 tall
-was a mofo to fit, i would go 16.5 deep next time
-cleared 6x9's but not black box. im sure if it was 16.5 tall it would fit under black box freeing up more trunk space.
YES, 15's will fit in both the sedan and coupe
the two sizes:
