The "DOES IT FIT?(parts)" Thread
Darianjr1
Newport News, Va
Would it be more cost affective going with a F or H motor rather than doing the whole J30 motor and tranny?
if you already got the f series in your car id say that would be cheaper.. if you do the j swap do j32 and thats might be a lil more than the h swap since you got to get a new subframe dont quote me on that but Id say J would be cheaper for real
For the most part, yes. Putting an F or H in there means you can keep things like motor mounts, etc. To my knowledge J's and what's needed to run them are more expensive in general. But the biggest difference is in the headache....a lot of things will need rearranged/rerouted if you put a V6 in there, and you'll need a new subframe as well.
But the real reason I do not recommend you going to V6 is because you have a manual now, I would not recommend switching to a 4spd auto slushbox. You would not want to go to all that trouble of swapping the V6 and then not have a 6spd. But as has been said over and over, it makes more sense to sell your car, and get a V6 to start with.
I would highly advise you to stay with F or H.
Darianjr1
Newport News, Va
For the most part, yes. Putting an F or H in there means you can keep things like motor mounts, etc. But the big difference is in the headache....a lot of things will need rearranged/rerouted if you put a V6 in there, and you'll need a new subframe as well.
But the real reason I do not recommend you going to V6 is because you have a manual now, I would not recommend you switching to a 4spd auto slushbox.
He could do the j30 with 6 speed
^Right, but at that point he would be better off selling his car and starting with a V6 Accord.
JordanFleenor
Bristol , TN
Ok J is out of the question. Thanks guys so much for helping me out.
Another question, will an H motor (ex. H22) bolt up perfectly or will I have to switch out a bunch of things for it too?
H22 will bolt right up to your 5spd. If you're considering that, I'd start researching, there's tons of info on the H22 here. :)
