Mikey
Odd that they'd get rid of the other light in order to make one a rear fog. I'd think they'd just do like other brands and make that one light a constant bright, like a brake light that's stuck on. Like this...
no beep between 2 and three with switch off. its an AT transmission by the way.
ill look at brake switch adjustment. any tips on how you got yours working when you did adjustment? Thanks
Where are you getting your procedures from? Is it from the actual Honda service manual? I like it
The less adjustment you do, the better. But you also don't want it to be at a point where a bump in the road shuts it off. Adjusting the pedal is not important. Adjusting the sensor is where I would start honestly. If the pedal functions properly where it is, it has worn together with the rest of the part so I say leave it alone.
Break the lock nut loose and start with one full 360 degree turn on the sensor, lock the nut and try again. Make sure it doesn't ever actually push down on the pedal.
Does the cruise light on your dash come on currently when you try to engage? Just making sure it isn't.
Yeah service manual pdf.
A bit of adjustment and its engaging now. Button still doesn't illuminate, even with headlights on but thats not a big deal. i'm getting 'cruise control' lit up on dash and its working as it should.
Thanks james!
Awesome! Now, are you talking about the word or the green light or both?
Just the main cruise switch button, should it illuminate with a light when pressed?
