cvjoint
Brought it back from Big O after doing an alignment with two major setbacks:
1. Front Left wheel gets about 1 degree negative camber more (I adjusted them to -1.6 with Ingalls adjustible arms)
2. Caster is way off: Front Left 1 degree positive, Front Right -.5 degree. Specified range for our cars is 1.8 to 3.8 degrees positive
I believe the negative/too low caster is to blame for the wondering under acceleration too.
Work previously done: V6 brake/spindle swap, tie rods inner and outers replaced and changed from one Ingalls adjustable arm up front to another that allows more negative camber.
So my question is, for those of you that got the V6 brake swap done did you get the same low caster numbers? Do I need to swap some radius rods out from the V6 model or what?
*Edit: I just checked Majestic Honda, the radius rods are indeed different from V6 to 4 cyl model. This might be it ceteris paribus of course, I hope no other related parts are different between V6 and 4 cyl.
I've heard we can add shims to the radius rods to add more caster, has anybody done this?
