Russianred
Snail Spools You!
ok i take it back about the tire wear...
when you floor it...esp if you aren't dropped...your front end raises right?...maybe the side where yoou just replaced the endlink isn't raising as much as the other side...i dunno just a theory..but check ur other endlink
The opposite endlink is intact, and i compared the old to new endlink, it's not like one is longer than the other one. I'm thinking that it just hasn't been broken in yet, and the pivots under the link boot are stiff. I tried driving around aggressively to loosen it up, but still pulls. Yeah when i wot, the front raises. If unequal tension was placed on the front sway, would it cause a side pull on acceleration, while going straight? If so, I am wondering what is causing this uneven tension...
Any more ideas?
