WTB 5 spd swap parts
workman8505
Knoxville, TN.
I am getting ready once again To do my 5 spd swap I am in need of everything except for the ecu. So if anyone has parts to offer just let me know. Thank you guys
Edit*
This is a f23 5sp swap stock the only part I don't need is a dvi cause I got lucky at pull a part and found one and already did the immobilizer swap.
SykVSyx
Tee Dot Ohh
I have these parts for sale.
6spd swap parts - selling together:
The shifter is CL-S (bought from Tom/ComptechV6). The metal bracket is the stay for the shifter cables, it's brand new (part #24600-PYZ-000).
I am charging you the same prices for these parts as I bought them for since they are new, as through the site sponsor. Except for the shifter, which I am charging half of what it actually costs new.
Here's the breakown:
36760 SM4 003 - CLUTCH SWITCH ASSEMBLY 21.70
35710 SE3 A01 - CLUTCH SWITCH ASSEMBLY, INHIBITOR 34.64
46990 S84 A01 - CLUTCH PEDAL BRACKET 317.87
54203 S6M R01 - FLOATING COLLAR 19.12
46928 S5A A01 - MASTER CYLINDER SEAL 2.96
93405 08035 08 - BOLT WASHER 3.84 (X4)
95701 06012 08 - FLANGE BOLT 1.20 (X2)
90001 P7J 000 - SPECIAL BOLT 2.06 (X2)
46977 SDP A01 - CLUTCH PIPE CLAMP 2.86
95701 08055 08 - FLANGE BOLT 3.52 (X4)
46943 S5A 003 - RING SEAL 2.40
95701 06016 08 - FLANGE BOLT 1.10 (X2)
Change wire stay - $20
Shift box - $25
TOTAL: $458.27
Link to pics here,
http://www.6thgenaccord.com/forums/showthread.php?t=37127
I have literally everything you need but I'm 8hrs away.
Clutch line
Slave Cyl
Master Cyl
Shifter linkage
Trans
Both axles & halfshaft
Starter
New clutch & flywheel (exedy)
ECU w/ immobilizer removed w/ VIN of original car it came from
Probably forgetting something but I know I have it all. Make me an offer and if it's worth the drive of meeting halfway, I'm down. Everything was installed in my car, never got it finished b/c I scrapped the car. So it's literally ALL brand new OEM (except clutch & flywheel) other than being installed for a few months. It's been sitting in a plastic container in my parents garage for the past I dunno....4-5yrs.
