F23A1AT
Ken specifically told me on the phone in his words to raise or lower the car using method 1.
Well, I guarantee you what you were doing is moving them up or down. The threads are so fine, it takes a LOT of turning.
So there's two ways you can do it:
1. Twist the paired collars (like you quickly demonstrated) to the left to lower the threaded body down into the red base of the coilover.
2. Remove the very bottom of the coilover from the knuckle (so its completely free) and spin the entire red base of the coilover up the threaded body.
Both ways take a little time and patience
And make sure you tighten the bottom collar to the red base once you're done!
^^ You don't have to by doing method #1. Not the "proper" way to do it tho, haha.
wait is that for type 1? lol
type 2 you have to take out the bolt in the rear in order to turn it....
Looks like you pulled them completely out from lower red housing... hopefully, you haven't ruined threads. Anyways, you need to turn the opposite way so it threads the gold threaded section INTO the red lower case so the car lowers. Right now, by turning left "as on video" you're raising car.
If I were you, I'd pull them out and ensure you thread that gold shock section back into case before you try turning while on car.
NASOHC said:Method One is correct and the best.
NOTE: Both Type One and Type Two's are setup the same exact way (coupe or sedan too)... no difference. No need to remove lower red case to adjust height (front or back) - unless, you pull the whole threaded gold section as it appears, is what happened in this case.
