Going 18 inch (18x8 225/40/18)
GoldnKnight22
TWM:TLMF
NH
With a little fender rolling, you'll be okay with +35. You're obviously not slammed on springs and Koni's.
There's no need to call a respected member an A-hole, either. AllGonoSHOW had a very valid point. I was going to tell you the same thing... without knowing the offset, the thread was useless.
4door accord02
Alberta,Canada
respected member or not theres no need for him to be a dink also,theres other ways to get your point across.... thanks for your insight tho should be good from here:)
4door accord02
Alberta,Canada
He has a point, this was said on the first page more than once. How low you are is quite relevant to your question. Though you have been instructed how to find out how low you are currently, so that should help in resolving your question. Have you figured it out?
ill do up my measurements tonite
JMillerUA6
Grillin' rape steaks
W. Hartford, CT
Just so you know, the wheels I had on my Accord were 18x7.5 +40 with 225/40/18's and my rears rubbed like a son of a *****.
I was lowered about 3"
hellfire127
Somewhere
I have 18x8 wheels, forgot offset, with 225/40/18 and only my rear rubbed. i had the eibach springs and struts, dropped 1.5".
rolled my fenders and they still rubbed. had to put some spring spacers to raise the car up a bit to stop some rubbing. now it rubs with passengers or lot weigh in rear as well as hard corners/turns.
just bought some tein ss coilovers to see if it'll fix my problem.
4door accord02
Alberta,Canada
so i fanlly did the 5 lug swap for my wheels on the rear only as im waiting one of the front knuckles... i rolled both rear fenders and when i went for a test drive yesterday.. every time i hit a bump and get a sequealing sound on both sides... now what other ways can i get rid of the rubbing problem??
what i was thinking is that can go get an alignment and get the camber adjusted? or mess around witht the bumper tab???
SykVSyx
Tee Dot Ohh
My suggestion......search.
On here and on V6P, there are threads that have been made that address these types of issues.
AllGOnoSHOW
asdfasdfasdf
Speaking of ''Useless'' Your post was pretty useless.. stop wasting your time :asshole:
Please don't make yourself look immature and semi stupid. My post was 100% relevant to your original post. I've already been through this and know what I'm talking about. Please go into your room and take a time out.
:thumbup:
Seriously though, I'll try to be more empathetic next time, I apologize but don't be so sensitive to the internet :)
4door accord02
Alberta,Canada
:thumbup:
do u have sand stuck in your vagina??? my offset was put up weeks ago...your recent post are useless and not even relevant.. you just confirmed how useless you are...
