FunnyVictor86
fyi specified factory oil weight is for new cars ... as they get older you need to get a thicker weight ... i usually use 5w30 or 10w30 depending on the season
Alright Wicked. So these are the 2 right?
http://www.stp.com/oil_4cyl.php
http://www.rislone.ca/34100.htm
Thanks
You guys need to be able to understand the viscosity numbers first. The "5" is the weight when its cold, the "30" is the weight when its hot. So going from 5w30 to 10w30 isnt going to be any different when the car is hot. If you want a thicker oil, go to 10w40.
Oh mechanic-in-a-bottle...
Oh, and you've never used any type of fuel, oil, coolant, or tranny additives to help preserve your vehicle, if you didn't have money to replace the parts.....
LOL, I think he's just joking around, because those products claim that its a permanent fix
I mean yeah, if you dont have money or whatever you can do that..
But IMO, I'd just man up and take the engine out, hone the block and replace the rings, probably grind the valves/seats, replace valve seals($1 a peice) cold tank the head and adjust valve lash. Call it a new engine and be done with it for a long time.
