kashmeister
Parts purchased:
2000 60675mi Manual Transmission (with speed sensor/reverse gear sensor)
98-02 Accord Shifter Assembly
98-02 Accord Shift Cables
Fidanza Short Shifter
Type R Shift Knob
JDM Shift Boot
93 Accord Clutch Master Cylinder
93 Accord Clutch Reservoir tank
93 Accord Clutch Line
93 Accord Clutch Dampener
98-02 F1 Racing Chromoly Flywheel
98-02 Exedy OEM Clutch Disc + Pressure Plate
90-93 Stainless steel line (hard line --> this --> slave cyl)
98-02 Manual Starter
98-02 Clutch slave cylinder
98-02 Clutch Master Cylinder
98-02 Drivers Side CV Axle
98-02 Halfshaft
98-02 Gas + brake Pedals
00 EX ECU
Mobil1 synthetic + purolator filter
wheel bearing grease for axles and stuff
Tranny Mounting Misc Parts:
3x Tranny mount to firewall bolt: 95701-12025-08 (If it doesn't come with the one I bought)
1x Tranny mount through bolt: 95801-12125-08
Drivetrain Misc Parts:
2x Halfshaft hex bolt: 90102-SF1-000
1x Halfshaft Bolt: 90165-SE0-000
Shifter Assembly Misc Parts:
1x Select Cable Linkage Pin: 54116-SV4-000
1x Select Cable Split Pin: 94201-20350 or 94201-20220
1x Shifter Nut: 90114-SA0-000
1x Shifter Washer 90551-SV4-000
2x Shift Cable Bracket Bolt: 93402-06012-08
Starter Misc Parts
1x Long Starter Bolt: 95701-12105-08
Clutch/Flywheel Misc Parts:
8x Flywheel Bolts: 90011-PH3-000
6x Pressure Plate Bolts: 90034-P10-A01
Clutch Line Misc Parts:
1x Master Cylinder Clip: 46924-S84-A02
1x Master Cylinder Lock Pin: 46911-S70-003
Clutch Housing Misc Parts:
1x Dowel Pin: 94301-14200
General Misc:
1x Clutch Fork/Shift cable/slave cyl **** urea grease: 08798-9002
2x Oil pan/tranny crush washer: 94109-14000
1x Trunk Latch: 74862-S84-A01
1x Valve Cover Bolt: 90013-P0A-000
1x Valve Cover Bolt Washer: 90442-P0A-000
_________________________________________________________________________________________________________________________________
NOTES TO SELF
-Thick Washers for Master Cylinder
Power Steering Fluid
Brake Fluid
Honda MTF (wtf is the part number?)
1/4" tubing to fill tranny
ball joint fork
Type R Shift Knob
JDM Shift Boot
98-02 Halfshaft
00 EX ECU
Starter Misc Parts
General Misc:
NOTES TO SELF
Brake Fluid
ball joint fork
