98-02 master and 98-02 slave
I bored out the master so ill probably have to get a new one if i go with OEM lines.
The hole on the master was too small for the flare fitting i got (it fit the slave perfectly), so i sanded it down and bored out the master cylinder to make it fit. It seemed to hold psi when i did a test with my thumb.
On majestic, theres 2 part numbers for the master cylinder. One is thicker in diameter and is for the original plastic master cylinder they were putting in the car. The other is for the newer metal master cylinder retrofit they had.
I dont know which one is which on the site, but the master cyl i got is a centric OE replacement and its all metal.
No rush on this though, I think i'm gonna JB-Weld the AN fitting to the master cylinder anyways, because I don't think the OE will work with the size I bored it to.
Its like $120 and $80 for each type of line (plastic or metal) on majestic, so get me a good deal if you pick it up
