HondaLuver83
A blown fuse prevents a reverse currant from running through your electrical system. In other words, its so you don't Fuk things up.Ok, so the Battery fuse (100A) is blown...
Is it correct to assume the blown fuse stopped any damage from happening? (The purpose of fuses right?)
How do I replace this fuse? I can't seem to be able to pull it out...is it screwed in or something?
If you dont know what your doing then maybe you should either consult someone on here or relate to the "BIG Three" thread again and make sure you do everything correct. Never under any circumstances mess with ground wires or any other wires while the car is running, you may seriously injure yourself or death.
As far as the fuse, I never had to take that one out. Try looking around for some screws that might hold it down like the previous member said. If you dont see any, get a pair of pliers to gently coax it out.
