car too bouncy camber kit................ help
truWarier02
Los Angeles
OP, how low are you (top of fender to ground)? Or do you have pics?
UCA will smack no matter what if you're low enough, probably 23.5" or lower.
'Tis I
the front camber kits decrease the clearance between itself and the strut tower. since the camber kit ball joints are taller than the oem ball joints, they could hit more often than the oem ones. granted ebay coilover sleeves are shit, but you said you started to hear the knocking after you put the front camber kit in. like i said, the knocking is because your upper control arm is hitting the strut tower, and the camber kit decreases the clearance you have there. the only solution is to raise your car a little bit...but raising cars is for pussies :lawl:
and your car is bouncy because of the ebay coilover sleeves.​
mr.6thgen
texas
the bouncy part isnt really a problem right now. i am saving for some better coilvers. but the camber kit is hitting the engine bay. the inside... idk what its called. i raised my car but the camber kit still hits
DarkSideAccord
nadeshiko fobz ftw..
take those front camber kits asap... one guy i knew had the camber kit tear thru into the engine bay
99accord boi
OC SoCal
did he hit a dip goin 40 with a car full of fat people?
i met a guy who hit his controls arms so hard everything flew in the air his stereo shut off momentarily he had change in his cup holder and that flew everywhere and wen we looked in his bay he had a small dent on the upper wells
