Search? What is this "search" you speak of?If you searched "p1457" you would've found a ton of info.
The gas cap code is P1456, P1457 is just for the EVAP canister valves and hoses.
If you searched "p1457" you would've found a ton of info. http://www.6thgenaccord.com/forums/search.php?searchid=987554
Here is the Accord TSB that applies to our vehicles:
So i have a CEL code p1457, bought a new canister, and shut off valve to replace. Then i noticed in the Accords equiped with A/T, it says to replace the PCM? Is this neccesary? Would appreciate some input.
