DIY: Front speaker mounting ring
Discussion in 'DIY - Do It Yourself Forum' started by xmsleepr, Jan 20, 2010.
  1. xmsleepr
    xmsleepr Well-Known Member
    237
    Dec 3, 2009
    not there
    later ill make a DIY on running speaker wire to the door, im putting 12awg for when I amplify my speakers those wont the speakers im running though havent decided on which components yet
  2. tckm
    tckm Well-Known Member
    177
    Sep 24, 2009
    AB
    ^^^ i need this!!!
    unless you arent running it through the boot...
  3. xmsleepr
    237
    Dec 3, 2009
    not there
    I'm running it thru the boot if it means taking my door off! Hopefully I can find an eaier method tho :p
  4. tckm
    177
    Sep 24, 2009
    AB
    yeah cause right now my speaker wire is just dangling from my door...
    and it looks forrible
  5. lashlee
    lashlee Well-Known Member
    42
    811
    7
    Feb 8, 2008
    Knoxville, TN
    Running it through the boot isn't that hard. I did mine years ago when I ran speakers in the doors. It's not too bad, just a little tight!
  6. RedAccord02
    RedAccord02 Well-Known Member
    301
    Feb 7, 2010
    Miami
    Put some Pioneer 6.5's 4 way using this technique its a great idea after u have it cut u can fit some deep speakers in there and the screws line up perfect thx
  7. xmsleepr
    237
    Dec 3, 2009
    not there
    no problem man glad i could help someone out.
  8. Fritz
    Fritz Well-Known Member
    70
    Jan 29, 2010
    Nashville, TN
    A Dremel is oh so handy for this job. I wish I had mine when I replaced my speakers. Ended up using some wire cutters and it worked okay.
  9. Soundmanred
    Soundmanred Member
    9
    Feb 13, 2010
    Tulsa
    I used a Dremel as well, and had to add a spacer to fit my CDTs in there.
Share This Page
