vishibhabra
does anybody knows the bulb size in manual climate control ? and how many do i need ?
I accidentally took off the whites from the needles and made it cleared but still looks ok but I dont like the hotspots on the temp consoles. Well here is the results:
anything red will not show up with blue led so i'll have to figure a way to make it show.
Maybe but you'd probably have to use a vinyl on the back side of the gauge itself and then use the red needles from the 01-02 cluster or vinyl wrap them in red as well with White LED's.
this is some great infoNp,
I've seen someone vinyl wrap their needles before and it turned out pretty well but never seen someone try putting anything behind the cluster to change the color. Other than removing what is there to make it 'white'.
The problem with doing blue or red is its a hollow inside so you'd have to pick one color, and being that red is on one side of the spectrum it would not shine through blue tint and vice versa. The only way you could get light through both colors is by using white since its visible through the entire spectrum of color
heres mine in red!
I forgot to order the bulb for the fuel meter, so thats why its still white =( but the rest is all good!
BTW the needles look orange in the picture, but in reality they are very red!
