Dumb question on remote wire
Madelinot169
Quebec, Canada
From my amp, to which wire would I run the remote wire? (Factory HU)
2002 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Green
Radio Ignition Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Valet
IS300 SX > Accord
Frederick, Maryland
On the back of the radio connect it to one of the ones labeled acc. Don't remember the color but it's on the diagram.
Edit: white and green I think. Unless you can find one that says acc. I really don't remember.
Nguyen916
Sacramento
I believe it is the Radio Ignition Switched 12V+ Wire: White/Red, so when your radio is on the amp will turn on.
Valet
IS300 SX > Accord
Frederick, Maryland
I used 24 gauge and no fuse. It really doesn't need it. And like he said you can do a switch like so,
so you can also manually control when it's on.
schmiddr2
Nashville TN
All power wire should be fused. It might prevent a fire if the wire is shorted. Other than that it doesn't change anything.
