h22 swap help!!!
jaron001
camden nj
yea idle air control thats what i need to get working. the yellow black wire is just the one that hooks up to the idle air control i was just looking over the prelude haynes and it listed the yel/black as - and the blk blu and + but maybe i just overlooked something. how did you run your idle air control once i figure out how you ran that i can get the car to idle
Drift
Mass
The Yel/Blk wire is the power to the IACV, the blu/yel wire goes to the ecu and the ecu will ground it using PWM. Thats really all you need to know. Make sure there is power on the yel/blk wire and that the other side eventually makes it to pin a9 on the p28.
There is a very good chance that the IACV is dead. The one that caem with my first motor was dead, and Ive done a few other honda swaps and found the IACV to be inop upon arrival.
Drift
Mass
If it mounts up, it will work. But make sure the wiring is correct before replacing it. Its just 2 wires.
jaron001
camden nj
ok so i just checked the a9 pin and the B23 pins they go to each other so i took the iacv off and cleaned it and the ports on the intake manifold. it was a just a sudden down pour of rain so i had to stop. but next gonna double check the wiring for the ect. then ill take it from there drift you are a big help i need to give you a tip for your efforts.
jaron001
camden nj
IT RUNS
so i had the ect hooked up all wrong lol :huh: drift the relay i guess it is in the harness where all the blk/yel wires 3 grn/blk and a few grounds go its on the side where the iat is. well anyways i had the iat and ect hooked to the wrong wire.
jaron001
camden nj
drift how loose was your throttle cable. i cant get mine to get tight the inner cable moves no matter where i put the lock not
Drift
Mass
Maybe about a cm of deflection. I run mine fairly tight for throttle response. But you dont want it so tight that its preloading the throttle aperture.
I also had to make a customer throttle cable bracket. I just remembered that.
