Hey guys! I haven't been active in a while but I figured I would pop on and ask for a little advice. I did some thorough searching and didn't find what I needed...
So I did a retrofit last fall. I had to cut a notch out of the black housing to get them to fit, but they were good after that. The shroud actually rubs against the lens but it isn't a big deal.
Now my problem is that while doing the first fitting I cracked one of my black housings. I still used them until garaging it for the winter, but everything was fine. Then this past spring I bought a new set of housings and swapped out the black housings and lenses. And now this is happening:
As you can see, it is melting the black housing. My last set was also from eBay (but turned out to be Depo brand). They didn't melt like this.
Has anyone else done a retro with eBay headlights and not have them melt? What seller did you buy from? Thanks for any help. I will be driving to Florida in August and I can't risk having any issues.
