FYI I've done the H22 swap and here what I did.
spec:
Accord 98 Sedan, 4 cyl
H22A4 From a 98 Prelude
You have 4 plug and play options
#1: OBD1 P13 or P28 chipped ECU with conversion harness (OBD2B -> OBD1)
this is the cheapest option, ECU is about 100$ and conversion harness about 30$
#2: Find a P13-A12 ECU from a 96 Prelude + conversion harness (OBD2B -> OBD2A)
somewhat more expensive, if you can find the ECU they usually run about 200$+, the conversion harness for some reason is expensive too, about 100$, however they are quite easy to make and cost about 20$ in parts. ---this is the option I went with---
#3- Get a standard H22 ECU OBD2A + conversion harness and use get the immobilizer chip from doctronics.
if I had 50$ laying around I'd try this one, I have an extra 98 ECU laying around, it's also from an automatic so I could try the manual to auto ecu convresion
#4- Get a standard H22 ECU OBD2A + conversion harness and have it reprogrammed at the dealer to use your keys
not sure how much this option costs... but I'm sure it's expensive and if the dealer is anything like the Honda dealers around here, once you show up with something that's not "stock" they back off really quick and say they don't know how to make it work
as a side note, if you have access to a good tuner, option #1 would yeild the best results.
