I got 10 quarts of oil... in my engine son!
GreddyAccord99
Boca Raton, FL
Get a Fel Pro gasket set (comes with the VC and tube seals) from Napa, they run about $30.
not a very good recommendation. I used this gasket for my first time changing it, and it leaks. I talked to a very trustworthy and intelligent mechanic who even stated that Fel Pro is garbage, and now I believe him. It would benefit him more to buy from the dealer because its reliable and cheaper! ($11.90 FTW!)
Just be careful with that.
They can break pretty easily then you'll be screwed
well...thats what i mean. the first time i screwed em in wasn't tight enough...and it allowed some seepage. took a tiny 10mm wrench and tightened them till they were just getting snug.
they must have backed up cause i could turn em by hand...
fel-pro is good stuff for certain things. some cars require OEM gaskets for stuff while fel-pro is good enough for others (or sometimes better. the fel-pro 4G63 kits are way better than mitsubishis, for example).
