Idle going really low after giving it gaz
Discussion in 'URGENT - Help Quick!' started by nathan007, May 11, 2017.
  1. nathan007
    nathan007 Well-Known Member
    120
    Nov 16, 2007
    Montreal
    Well cold seems to be around 1200 (need to confirm with digital tach), its not like stock when it runs 1500-1700 for a few minutes until engine warms up.., it will gradually go down to around 900-1000rpm until warm.
    I did check for vacuum leaks with starter fluid (spray); nothing. Alt seems to be supplying steadily 14.25v, when car is warm if I do turn the lights on, blower motor on, idle will drop even more and worsen situation after releasing throttle. I made a quick video , sorry its in French but to recap;
    Throttle body idle screw opened 3/4-1 turn compared to originally, initially running with no acc. On except parking lights, then blower motor at 3, and at last I rev it around 3k rpm, release throttle and quickly stab it about 1/2 and you see it bogs down for a sec (never had this kind of issue before)
    https://youtu.be/UtMNGat6UFA
    Sent from my 6045I using Tapatalk
Share This Page
