Alpha_Onion
I just installed my Prelude/Legend GS brake upgrade. I also swapped on some SS lines, and decided to replace my rear calipers, pads and rotors while I'm at it. Here's my problem:
I did one corner at a time, and when I was done I tightened everything up and bled the calipers. The front ones had a little bit of air, but nothing too bad. As for the rears, OH THE FUCKING REARS.
I swear I have bled them both about 30 times each, and the bubbles just keep coming. And they're not getting less and less each time either, it's consistently the same amount of air every time.
I already went around and double-checked every bolt I touched, making sure they're all super tight. I have no leaks anywhere, and I've been topping off my master cylinder between each bleed. There is no logical way that I could've had this much air in my system, or my brakes wouldn't have worked at all before I did this. So where is it coming from?
Anyone with info or suggestions, I would highly appreciate your input so I can get this solved and also not die. Thanks!
