AllGOnoSHOW
Very nice!!
looks nice man.
what kind of pads you using?
damn... tht's crazy expensive lol
balla![]()
just for the calipers you will need ... this is if you are already a v6 or 5 lug swapped ... all you'll need nsx calipers and nsx caliper brackets ... now the nsx brackets looked similar to the v6 brackets but i didn't check if they were interchangeable or not ... and the mounting hardware for the brakes lines will have to be re-mounted because the lines will no longer reach the caliper without kinking the lines ... or you can pick up a set of ss lines that are about two to three inches longer than stock and that's it ... throw them on ... bleed the brakes and ur done ... i wish i could have done a real write up but i was too busy fighting with the rain
parts used:
-nsx calipers w/ brackets
-nsx or v6 brake pads w/ hardware
-brake fluid
