Offset choices
SykVSyx
Tee Dot Ohh
No, I know what you mean....there are plenty of examples on here.
I think you are better off with a 215 tire and about -2 to -3 camber, in the rear. Front end, you should be fine.
jdm egizzle 6
phx
215 tires and get 30 offset. that should be like -2ish camber
I can't find other offsets for the 4 lug!
Did you contact Wheeldude about the Rota's? They usually have good prices
is he legit? I've been looking at some of his selections along with aspecwheels that jeff told me about. It's hard to find rims here in az(for4x114.3) so I need to make sure the source is good and that I get a good offset. Only person that deals with rota in az is "versus" and the grids cost me a grand with tires so I have to look extra hard.
truWarier02
Los Angeles
Good choice slapping on some Ksports.. so not going low enough shouldn't be an issue.
If it hasn't already been stated, you can check out Johnson's car (member name: Johnson) for reference. 17x9 +12 is definitely possible.. just probably takes a little more work than the typical fender roll. Maybe a slight pull.
swollen_cu
New Orleans
You'll need a camber kit for the front only if you decde to go past a +25 offset. The rear should camber in at -3 when slammed
jeffpanya
what are you talking about you cant find the right wheel ? here you go is this what you wanted ? 17x9 with a 25 offset you will get the same exact poke as me since i am 17x9.5 with a 30 offset. :ughrun:
jdm egizzle 6
phx
I'm talking about the p45r I only found them in 17x9 +12 in 4x114.3. show me the +25 in p45 and I'll take my statement back and look like a idiot. As far as grids I haven't found a deal yet that wheel I found what I want but not the price.
