Super durable black paint for bracket/suspension/etc...advice?
talontsiawd
East Bay, CA
This is actually not for my Honda but I am sure a few of you may have repainted some rusted parts over the years. I am looking for a black paint (I don't really want gloss but can deal with it, satin/semi gloss would be best) for a lot of brackets and probably some suspension parts down the road. I would like something that is out of a spray can, dries fast, and holds up. I can deal with something that can be reduced and sprayed through an airbrush as well.
I know this sounds simple but I have yet to find anything that will hold up for long periods of time. Everything that is supposed to be durable in a spray can always sprays unevenly and takes forever to dry. I just want something quick and easy that looks pretty good for a long period of time, doesn't have to look great but has to hold up.
I know this is a really basic question but I have yet to find an answer.
crossfire
Washington
I would try epoxy paint from VHT. It's unforgiving in that once it's on it'll be a b*tch to remove. And the smoothness will be determined by your painting skills.
kashmeister
chicago
I have had good success with duplicolor high temp flat black engine paint.
The shocks on my BMW had a ton of surface rust and the paint worked perfectly.
If you can sandblast them otherwise sand by hand.
SykVSyx
Tee Dot Ohh
Hey Matt,
what did you end up going with?
I would agree that VHT makes some great products, including their high heat temp. paints.
AFAccord
Spangdahlem, Germany
The absolute best stuff to use is called POR-15. http://www.por15.com/
My dad and I have used it to coat the chassis and backside of body panels on our Vette restoration and currently a 65 Chevy pick-up. It's super tough, applies over almost any surface and won't chip or crack, even after I beat the crap out of it with a hammer or bend the panels.
Anything from a spray can simply won't hold up like you want. My $.02
SykVSyx
Tee Dot Ohh
^The Chassis Cote and Black Cote aerosol cans are also rust proof?
They don't really say, but I guess its implied.
Russianred
Snail Spools You!
Southern Maine [207]
Por15 is awesome stuff, and in my opinion the next step down would be a spray-can VHT Epoxy. I coated my 5-lug swap with it, looks great and provides rust protection. I would get Por15 if you can though.
SykVSyx
Tee Dot Ohh
Sounds like a good product, do they have a high temp version as well?
I may have missed it, but I didn't recall reading that from the website.
