Torq Specs
Honda4Life
Central Coast, California
So I want to create a sticky where we can have a reference for all the major nuts torq specs. I do not know them but please let me know what they are so I can update the page.
Lug Nuts -
Transmission Drain Plug -
Oil Drain Plug -
Spark Plugs -
Calipers bolts -
Rotor Bolt -
Valve Cover Bolts -
And feel free to add additional bolts...
crossfire
Washington
Off the top of my head
Lug Nuts-80lbs/ft definitely right at least for a V6
Oil Drain Plug-24lbs/ft
Caliper Bolts-27lbs/ft
001Stunna
Toronto, ON CANADA
Torque Specs (ft/lbs)
Auto Drain Plug: 36
Manual Drain Plug: 29
SparkPlug: 156 in/lbs
Wheel Lug Nuts: 80
Water Pump Retaining Bolts: 104 in/lbs
Thermostat housing cover bolts: 104in/lbs
Throttle Body Mounting Nuts: 16
Fuel Pressure Regulator:
...i4: 108in/lbs
...v6: 22
Fuel Pulsation Damper: 16
Engine Stiffener Bolt:
...i4: 10mm bolt: 33
...i4: 12mm bolt: 47
...v6: 28
Transaxle to engine bolts: 47
Subframe Mounting Bolts:
...10mm: 47
...12mm: 75
Clutch Master Cylinder mounting nuts: 110in/lbs
Clutch release cylinder mounting bolts: 17
Clutch pressure plate bolts: 19
Drive-axle/Hub Nut: 181
Intermediate shaft bearing support bolts: 29
Brake Hose to caliper banjo bolt: 25
Master Cylinder Mounting Nuts: 132in/lbs
Strut brace mounting nut: 16
Brake booster mounting nuts: 110in/lbs
Wheel sensor mounting bolts: 88in/lbs
Wheel speed sensor bracket nut: 84in/lbs
Front Caliper Mounting Bolts:
...i4: 54
...v6: 36
Front Caliper Mounting Bracket Bolt: 80
Rear Caliper Mounting Bolts:19
Rear Caliper Mounting Bracket Bolt: 28
Disc to hub screws: 84in/lb
Rear wheel cylinder nuts: 80in/lbs
Front Damper Fork Pinch Bolt: 32
Front Damper fork to lower control arm through bolt/nut: 47
Front Lower control arm inner pivot bolt: 47
Front Radius rod to lower control arm bolts 119
Front Radius Rod to crossmember nut: 32
Front Damper to Chassis Body Bolts/Nuts:
...8mm: 144in/lbs
...10mm: 37
Front Damper Shaft Nut: 22
Front Stabilizer Bar Link Nut: 29
Front Stabilizer Bar Bracket Bolts: 22
Front Lower BallJoint Nut: 36-43
Front Upper Balljoint Nut: 29-35
Front Upper Control Arm Pivot Bolts: 47
Rear lower arm inner pivot bolt: 43
Rear Lower arm to knuckle bolt/nut:43
Rear Control arm inner pivot bolt/nut:40
Rear Control arm to knuckle nut:43
Rear Trailing arm to chassis bolt:43
Rear Trailing arm to knuckle bolt:43
Rear Leading arm inner pivot bolt:43
Rear Leading arm to knuckle bolt:43
Rear Upper arm inner pivot bolt:43
Rear Upper arm to knuckle castle nut:36-43
Rear Hub Nut: 139
Rear Damper Shaft Nut: 22
Rear Stabilizer bar link nut: 29
Rear Stabilizer bar bracket bolts: 22
Rear Shock absorber to knuckle bolt: 43
Rear Shock absorber upper mounting bolts: 37
Front Steering Intermediate shaft pinch bolt: 16
Power Steering Pump Mounting Bolt: 16
Power Steering Line bolts: 96 in/lbs
Steering Wheel Nut: 29
TieRod End to steering knuckle nut: 32
For I4 Engines
Fuel Rail Mounting Bolts: 102in/lbs
Air Intake Plenum Bolts: 16
Valve Cover Bolts: 86 in/lbs
Balance Shaft/Timing Belt Tensioner Nut: 33
Camshaft sprocket bolt: 43
Crankshaft pulley bolt: 181
Flywheel to crankshaft bolt: 76
Drive-plate to crankshaft bolt: 54
Intake Manifold nuts: 16
Exhaust Manifold nuts: 23
Balance Shaft Front/Rear Sprocket Bolt: 22/18
Oil pan to engine bolts: 120 in/lbs
Oil pump housing bolts: 104in/lbs
Rear Main Seal housing bolts: 104in/lbs
Timing Belt Cover Bolts: 104in/lbs
Front Engine Mount:
...Bracket to chassis bolt: 28
...Bracket to engine bolts: 28
...Through Bolt: 47
Rear Engine Mount:
...Mount to chassis bolts: 28
...Bracket to engine bolts: 40
...Nut for mount stud: 40
Left Engine Mount
...Bracket to engine bolt/nuts: 40
Right engine mount
...Through bolt: 40
...Bracket to tranaxle nut: 28
FOR V6 ENGINES
Camshaft thrust plate bolt: 16
Camshaft sprocket bolts: 67
Valve cover bolts: 104 in/lbs
Driveplate bolts: 54
Exhaust Manifold Nuts: 23
Exhaust heat shield bolts: 16
Intake manifold nuts/bolts: 16
Oil Pan Bolts/Nuts: 104 in/lb
Oil Pan Drain Plug: 29
Timing Belt Tensioner Bolt: 104in/lbs
Timing Belt Idler Bolt: 33
Rear Main Seal Oil Retainer Bolt: 104in/lbs
Left Side engine mount engine bracket bolt: 33
Left Side engine mount insulator through bolt: 40
Front engine mount engine bracket bolt: 28
Rear engine mount engine bracket bolts: 28
Engine mount insulator nut front and rear: 40
Passenger side engine mount bolts: 28
Other
Engine Oil with Filter
...V6: 4.6 quarts
...I4: 4.5 quarts
AutoTranny Fluid
...V6: 3.1 quarts
...I4: 2.6 quarts
ManualTranny Fluid
...I4: 2 quarts
Coolant
...v6: 5.9 quarts
...i4: 5.7 quarts(auto) 5.8 quarts(manual)
Sparkplug Gap
...0.039-0.043inch
Engine Firing Order
...i4: 1 3 4 2
...v6: 1 4 2 5 3 6
Idle Speed
...i4: 650-750
...v6: 630-730
Valve Clearnaces(cold engine)
Intake
...i4: .009-.011inch
...v6: .008-.009inch
Exhaust
...v6 & i4: .011-.013inch
Cyl Cylinder Compression Test Pressure(at WOT)
...Standard: 178psi
...Minimum: 135psi
...Max variation between cylinders: 28psi
Cyl Oil Pressure(warm engine)
...i4: At 3000rpm: 50psi
...i4: at idle: 10psi minimum
...v6: At 3000rpm: 71psi
...v6: at idle: 10psi minimum
Fuel Pressure Key on/Engine Off: 47-54 psi
Fuel Pressure at idle
...i4: vacuum hose attached: 38-46psi
...i4: vacuum hose detached: 47-54psi
...v6: vacuum hose attached: 32-40psi
...v6: vacuum hose detached: 41-48psi
Fuel Pump Max Pressure: 65psi
Battery Voltage:
...Engine off: 11.5-12
...Engine on: 13.5-15
Ignition Timing:
...i4: 12Degrees +/-2 BTDC in Park or Neutral
...v6: 10degrees +/-2 BTDC in park or neutral
001Stunna
Toronto, ON CANADA
Russianred
Snail Spools You!
Southern Maine [207]
This info is indeed posted elsewhere, but please do NOT delete this thread.. This is a GREAT compilation, in case someone can't find the other thread.. typing 'torque specs' in search will SURELY pull this one up for even the n00b user!!
Thanks Levin!! Repped!! :D
