where to jack
dvilla5506
garden grove ca
where the hell do u jack up the car to change the oil ive always got it done at a shop and i tried to do it but cant find a spot to jack it up safely.........if u got pics that wud help alot thanks
1NonlyAccord
GA
http://syclone.motocrew.com/CG5/jackpoints.htm
Front theres a thick metal slab on the subframe you place the jack.You probably have the engine cover under it to hide it.
rear;I wouldnt use the tow hook,i bent mine..Go next to the exhaust on the rear chross member,but watch your jack due to the gas tank is on the other side.
Or for wheel changes ect,on the side on the pitch welds.
RedAccord02
Miami
why dont you buy the plastic ramps from your local auto parts store. Ive used them on all types of vehicles theyre very sturdy and make the job alot easier and safer. Long as you dont launch the car off them u should be fine :lawl:
