Xm radio antenna
JDM_Rook
Winchester, VA
I am looking to replace my magnetic Xm radio antenna with a Terk glass mounted type which is outdated. The magnetic type seem to leave scratches
and even though I tucked the wires like is shown here, http://www.6thgenaccord.com/forums/showthread.php?t=551&highlight=xm+radio+antenna they would always work it's way loose after awhile. I think this older 2 wire antenna should still work with my Delphi Skyfi2, if I only use the Curry (satellite) wire. Anyone here use a glass mounted antenna?
ejreams
Fort Collins, CO
Dude. leave it inside the car on the dashboard on the passengers side in the corner.
Thats what I did, no problems. ever.
lashlee
Knoxville, TN
I put a few on years ago. I would look into putting the OEM antenna on the dash or rear deck. I had mine on the dash then moved to the rear deck. They make a two wire to one wire adapter if you look around for one.
