BlackestCoupe
This is directly from the directions I got from F2 autolife.
1. First tighten the two locking collars under the spring with the provided wrenches. One holds the spring perch, which is located directly under the spring. The other wrench tightens the locking collar in place. Locking these two collars together allows the spring and shock body to rotate as one with the lower mount. This is important as it allows you to lower the vehicle while retaining full stroke of the shock.
2. Next untighten the gold locking collar above the lower perch.
3. By inserting the wrench inside the locking collar notch, and spinning them clockwise ( to lower the car) , or counter clockwise (to raise the car). The entire shock assembly, including the spring, should rotate inside the lower mount. This is how you raise or lower the shocks position in the shock mount, thus raising or lowering the car's height.
4. Once you have adjusted suspension to desired height, lock the gold perch above the shock mount. Double check all four corners to make sure all locking collars are tight and no bolts are loose.
Why is this so confusing. Lowering this way does not alter the pre-load and is exactly how Function and Form recommends lowering your car. End of story.
