01 Accord 6Speed True Manual No Spark
OldNo7_CG2
HeLL
i have an 01 Accord V6 with a J30A1 and an 05 TL 6 speed trans that i did a true manual swap on. Car ran with the auto ecu sensors and wiring harness. since the swap i get no spark but i get 12v power at the coils with the key on and 12v ground, fuel is good and car cranks but wont kick over. sounds like it wants to kick over but doesnt
i swapped the following parts
03 cls6 flywheel
03 cls6 flywheel crank sensor
03 cls6 front cam backing plate/cam gear &sensors
03 cls6 crank gear and sensor
03 cls6 manual ecu
03 cls6 manual engine harness
re wired my stock A clip to the cls6 E clip
i also had the trans clutch housing worked by Paul to fit the 03 CLS6 crank sensor.
any suggestions?
purpleaccord
charlotte
That's the problem.... You have to reprogram your key to match with your ECU.... The only thing you can do,bring your car to dealer and reprogram your key.
OldNo7_CG2
HeLL
The green light that is supposed to come on for immobilizer doesn't even light up anymore. If it was an immobilizer issue it would blink constanty
WHEEELMAN
Georgia
Immobilizer Chip is pulled, immobilizer/reprogramming the key is not an issue.
** What did you do as far as the knock sensor from the cl-s ecu? The J30A1 doesn't have a knock sensor. I'm wondering if the knock sensor would be the cause? If the CL-s ECU is not getting that knock sensor signal, maybe it wont let it fire up?
I have asked Smalser if this could be bypassed or "fooled" and he said "no".
OldNo7_CG2
HeLL
The J30 has a threaded port in the block under the front intake runner for the knock sensor. I threaded one in and wired it up.
OldNo7_CG2
HeLL
Negative car is still not getting spark. Been busy with work trying to get this running ASAP I think one of the crank sensors is defective
