JediYuhdigg
Since I was on a pretty tight budget, I went with the Interstate Megatron Plus. 750CCA. Comes with a 85mo warranty. Picked it up for $90 at a local tire shop. So far so good!
you guys running any electrical mods that could drain more than usual? ex: aftermarket sound system, HIDs etc..
duracell
Optima is a good choice when it comes to running amps, HID's, subs and in area's where it's either hot in the summer and cold in the winter. A little pricey, but a good battery with a long battery life of around 7 years. I don't know why someone earlier said 3-4 years. That's not true.
Not necessarily this specific one, but if car audio is on your to do list, you may want to consider,
Odyssey sells batteries, weight saving oriented, and heavy duty as well.
Wrong. You also void Optimas warranty if you use it to power 'thirsty' car stereos. I guess you've never seen an Optima explode?
Then dropping water in cell phones to get the newer version that came out voids warranty too....
How'd u make an optima explode...abuse of current and voltage? I see that DD on your sig.
http://www.shurikenonline.com/
this is what i will be running once i have loot for it, gotta build my box first i do car audio competition and me and my friends research has lead us to this line of battery, maybe down the line for you, we have one installed in a mini at the moment and works very well, its a glass pack type of battery check it out Shuriken ftw
