CF4 Fog light install
silver_accord
fresno ca
is there someone here with this already? been looking but cant find any. and what kind of mods do i need? :computer:
SykVSyx
Tee Dot Ohh
Too bad there are no pics of my car, IHazSnail's car, or ponglynn's car or Bkztaffeta's car with these on them.
:coffee:
ponglynn777
philippines
ok...if you are using 1998-2001 bumper it doesnt look good, but if u r using 2002 extended vent u r in good hands
first you need to shave the outer column vent of ur bumper, be careful to cut it, it should be same as the other side, i used steel saw cartridge manually, the major mod is to cut your front chassi frame beam atleast 3/4 inch coz if u dont the fog will hit and it wont fit perfectly to ur bumper, fog will pop out and ur in trouble, then fog switch, DIY harness, separate 12v. tap to ur battery w/fuse and ur done.
heres w/98 bumper
w/02 bumper
inspiration
goodluck
JetLife
Maryland
heres w/98 bumper
w/02 bumper
inspiration
goodluck
im really interested in doing this. i dont understand how it stays in place. did you have to make a braket of some sort? do you have any High res pics close up?
ponglynn777
philippines
any light flex metal will do, drill holes at every end and some screws to make it a braket. i dont have HS pics but ill try to take some and post it later
LowerMyCG5
hampton va
Personally I think these fogs only look good ob 01-02 coupe bumpers. They look out of place on the sedans
JetLife
Maryland
okay cool thanks. appropriate it. i was thinking either way im gonna have to cut my bumper for the OEM so why not get things and be different
