the moogs are even cheaper than the no-name ones with my hookupsWill you go with the OEM bushings or pick up a set of some polyurethane bushings?
Knowing Ryan, probably non-OEM rubber bushings...
hey, ive been having this issue too, and today i took it to a shop and they put it on the lift and since i dont trust mechanics i was right next to him and took the opportunity to check for rattles. Everything was firm except for the actually sway bar which had some play at the bushings which what i think was causing the noise
my bushings look good and i can't feel any play in the bar...that's what SHOULD be making the sound...
hell, the bushing kit is $11 so i might as well do it. the rears were definitely toasted last year so the fronts can't be that good, either.
