1NonlyAccord
GA
I used my stock coupe i4 ex rear calipers,worked just fine. Just bolted in a new v6 wheel hub and put v6 rotors on.good to go.
snip33r
Mississauga
want to ask if 5 bolts conversion from 01-03 Cl-S will work on our cars or not
lashlee
Knoxville, TN
Rear calipers have two differences: the piston has a slot on the coupe and a plus sign shaped slot on the sedan as well as the bracket for the parking brake line. The coupe is slightly shorter. They both will work if doing a swap, and the pads are the same.
i don't know for sure, but i would think it would. people have used 2nd gen tl spindles in the past and that has worked. the 2nd gen tl's and cl's share the same suspension with the accord, so it probably would work.
snip33r
Mississauga
Thanks, time to pay a visit to junk yard for 5 bolts conversion
Varnell
Charlotte, NC
I bought knuckles when I did my swap and luckily I was able to get them from a v6 sedan so everything lined up perfectly. There is no difference in the front calipers, only the rear
Where did you buy your knuckles? That's the only part O'Reilly's didn't carry.
Also, what length brake lines/parking break lines would I need for my '98 Lx i4? They gave me six different lengths and I just priced the longest one.
kamozee
Toronto
I got them from a junkyard when I was visiting Michigan
Check out car-part.com
Varnell
Charlotte, NC
Thanks! That's a pretty useful site. I'm trying to avoid the junk yard since I'm the most knowledgeable about cars of anyone I know (that's not saying much), and I don't feel confident deciphering between a good knuckle and a bad one.
Varnell
Charlotte, NC
Not sure if you're referring to me, but I didn't see a specified parking brake line length.
I figured too long would be better than going too short.
